front
when object #2 is active, i want to the others are passive.
when object #4 is active, i want to the others are passive.
i want to selected object in the front panel is active, the others are passive
Message 1 of 8
(3,869 Views)
Please define what you mean by "active" and "passive". Are you referring to disabled? Disabled and greyed out? Visible?
Message 2 of 8
(3,865 Views)
yes, it is like disable options. for example when the selected object rotates by pushing a button, the other objects or boxes are not affected. then when i select the other object (box #2), i want to box #3, #4,.. etc. are not affected.
Thanks!
~drycsr~
Message 3 of 8
(3,855 Views)
I'm sorry, but your explanation is not clear. Now you're talking about rotating. Your screenshot seems to show what might be a picture indicator? Are you drawing these boxes? Can you post your VI?
Message 4 of 8
(3,831 Views)
Message 5 of 8
(3,814 Views)
rotating is just an example to explain what i want. shortly, we want to the selected object in the front panel is active, the others are passive. thank you!
Thanks!
~drycsr~
Message 6 of 8
(3,776 Views)
You have way too many loops and event structures. You only need one loop and one event structure. You can use the Disabled property for the controls to simply disable the ones you want based on your conditions.
Message 7 of 8
(3,756 Views)
This discussion has moved here.
Message 8 of 8
(3,661 Views)
