fpga vi compilation error
when I run to complile my FPGA VI, I get the follwoing error:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
nirviRequestAResetCyclesForCLIP.vi<-nirviGetVitalTSInfoForBackend.vi<-nirviGetConfiguredClocks.vi<-nirviGetConfiguredClocks.vi.ProxyCaller
              <APPEND>
No connection for instantiated signal
can someone tell me why do I get this error?
(4,852 Views)
Could you give me more details about your Labview FPGA version and your application.
I encounter a problem after Developer Suite 2012 installation.
When I compiled a FPGA code, I always have a generic error.
To see my old post, you can follow this link :
http://forums.ni.com/t5/Real-Time-Measurement-and/Labview-FPGA-compilation-on-cRIO-9082-RT-crash/m-p...
I hope this post help you.
R. Kaszubiak
(4,819 Views)
It would be helpful if you could give a little more description into the error surrounding the FPGA VI compilation.
-When exactly does the error occur (during, before or after compilation)?
-Is there any other information that comes up with the error (error codes, etc)?
-What version of LabVIEW are you using, as well as what kind of hardware?
dK
(4,801 Views)
 i get  during the compilation this error mesage:
<APPEND>
can someone help me  to solve it ?
PS: i use labview 14, Hardware PXIe 7965R
(4,638 Views)
Hi Alino
Could you try the following steps and see if it resolves your issue?
1. Right click FPGA>>New FPGA Base Clock
2. Add the 200MHz Clock
3. Go to the properties of the IO Module
4. Go to Clock Selections
5. Select the 200 MHz clock
Please let me know whether this resolves your issue!
Andy F.
Applications Engineering
(4,602 Views)
Hi ANDROID_FREEBOT,
thank you Smiley Happy these Steps resolve it.
Regards
Alino
(4,579 Views)
