Showing results forĀ
Search instead forĀ
Did you mean:Ā
fixed width font in string control
I am doing some alignment in the text control and want to use "fixed-point" or monospaced font, Consolas.
The Consolas font is very basic font in all Windows and Notepad and shows "zero(0)" treatment as you can see the attachment.
I set the font for a string control, the string control shows the different font though property node showed the intended information.
(I have to notice that Labview font dialog shows the right information.)
My problem is that the font, Consolas, can find Notepad and Windows but cannot display it rightly on the string control.
Can you help how can I check this problem?
Attachment: comparison of each program.
labmaster.
*) Other Korean default font shows the fixed width in strong control as attachment.
Message 1 of 39
(8,379 Views)
It displays for me with no problem (see picture below). It looks like you haven't change the font of the actual control.
The font ring does not display the font of the currently selected control UNLESS the text cursor is inside the control. Then it will show you the current font selection. What it does show is the default font selection if you were to drop a new control.
Put your text cursor inside your text box -- I bet the ring changes to some other font.
Select the whole control and then change the font ring to Consolas (even though it is already showing Consolas, select it again anyway). That'll set it.
Message 2 of 39
(8,327 Views)
My question is not how to apply for the font to the string control.
Your font, Consolas, is not real fixed width font and cannot align some combined text (space or different width letters) with that font.
My question is why they are different appearance in notepad or original font description of Wikipedia.
labmaster.
Message 3 of 39
(8,313 Views)
I am not sure I understand... that isn't our font... that's the Windows Consolas font. It looks the same in LabVIEW that it does in MSWord. And in both, it appears to be a fixed width font.
Message 4 of 39
(8,301 Views)
Thanks for your effort.
Here is the counter example in LabVIEW.
I am talking about the bug of LabVIEW and Consolas was well known as fix-width font.
Usually the problem of alignment was caused from special characters like blank +, -, ., \ etc.
Message 5 of 39
(8,275 Views)
If you use that same example in word, what do you see?
Message 6 of 39
(8,227 Views)
Thanks for the comment.
My example can be presented without a problem countrary to the case of Labview.
At this moment, why labVIEW can't present he fixed-width font on string control.
Please do not change the target.
For a long time, somebody replied the alignment can be achieved by array of string then be converted to spreadsheet.
I don't have any reason for alternative. In my opinion, just use fixed-width font like some c++ programmers.
You can find their favorite fonts for this alignment.
labmaster.
Message 7 of 39
(8,218 Views)
Hi labmaster,
we don't change the topic.
We all tell you Consolas is a monospaced font and it is displayed by LabVIEW as it should:
As it seems you're the only one having problems with this font you should check your computer and/or LabVIEW settings…
Message 8 of 39
(8,204 Views)
Many thanks.
That's what I want to know it.
Maybe, different configuration (version and language) could be a problem.
What is the default font of German notepad? (Maybe, Consolas?)
Did you try it with Courier?
The reason why I am asking the default font of notepad, only "one" default font (not Consolas or Courier) was presented rightly in my case.
Message 9 of 39
(8,191 Views)
Accepted by topic author labmaster
Hi labmaster,
Notepad uses Consolas by default, too.
Courier looks like this:
Message 10 of 39
(8,176 Views)
