fatal internal error: error "thevent.cpp"
I'm getting the following error when I shut down LV 2010.
   Fatal Internal Error: error "ThEvent.cpp", line 236.
A search of the NI site didn't help. What is causing this?
George
Message 1 of 13
(6,888 Views)
The error you are seeing is a bug in 2010 and has been submitted to R&D for corrective action. Should be fixed in LabVIEW 2010 SP1.
Jake H | Product Manager
Message 2 of 13
(6,868 Views)
I'm running LV2010 SP1, and getting this error.  it's not fixed.
Message 3 of 13
(6,747 Views)
Hi Britoa,
What are the steps to reproduce this error in LabVIEW 2010 SP1? Many instances that caused this error were fixed in the service pack but it is a generic error that may have previously unknown causes. If you can detail the process you went through when the error occurred I can reproduce it and report to R&D to make sure that it is fixed in a future version.
Message 4 of 13
(6,740 Views)
I'm getting this error trying to create a wrapper for a DLL.
I created a cluster of an array of CHAR (8 bit unsigned) and a WORD (16 bit unsigned).
I created a cluster of an array of the previous cluster and an integer.
I'm trying to mimic the code here:
// receives list of supported board types
DL615_SUPPORTED_BOARD_LIST boardList;
// obtain list of supported board types
dl615_get_supported_boards(&boardList);
Where DL615_SUPPORTED_BOARD_LIST is a struct of type:
typedef struct
INT numBoardTypes;
DL615_SUPPORTED_BOARD boardType[32];
} DL615_SUPPORTED_BOARD_LIST;
and
typedef struct
CHAR desc[32];
WORD type;
} DL615_SUPPORTED_BOARD;
Message 5 of 13
(6,665 Views)
What version of LabVIEW are you running?
Message 6 of 13
(6,650 Views)
2010 SP1
Message 7 of 13
(6,647 Views)
typedef struct
INT numBoardTypes;
and
typedef struct
CHAR desc[32];
WORD type;
Sadly, the array inside the cluster wont work for labview, it will turn it into a pointer.  If you feed in an array of U8s, 4+32*(1*32+2) long (int + 32 of (32 char + word)), it shouldn't give you grief.  but your output will come back as an array of U8s, so you will have to decode it. (first 4 U8s make the Int, next 32 are the name of the first, next two is the word for the first, then the second, etc.)
Message 8 of 13
(6,643 Views)
I tried that yesterday and if my math is correct I'd be looking at a single array of 1092 U8s.
I've tried using both stdcall (WINAPI) and C for the calling convention. Some of which crash LabVIEW without popups some of which crash with the ThEvent.cpp dialog shown above. I've also tried different data types. Nothing.
Message 9 of 13
(6,636 Views)
Ok, so I decided to be smart about this and output an array rather than adapting to type.
I'm actually getting data from this, I don't know if it's the correct data yet, but data is better than crashing.
Message 10 of 13
(6,631 Views)
