error 1 invalid in input parrameter + NI 488
Hi all,
Since I upgraded to LV 2009 and Win7 (I don't know if the issued is ralated) I have been having probem with my write to mesaurment file express vi.
No matter what I try or how simple I make the VI, I always get the same error.
As you can see,  I have a simulated signal that i being record, but everytime that I enable/disable the write to mesauement file I get this:
Like I said, this only began to happen with LV2009 and/or win7.
Roddy
Message 1 of 11
(5,598 Views)
The first part of that error is what applies to you, and the most likely reason is exactly what it says: check your path, including the name of the file itself to make sure you don't have illegal characters. 99.9999% of the time that's what the problem is.
Message 2 of 11
(5,590 Views)
beleive me, I already did that...
c:\sensor\try.lvm
Message 3 of 11
(5,578 Views)
Shot in the dark. Did you perhaps upgrade from XP? I thought I read online here how Windows doesn't let you write to certain areas anymore. Check your permissions.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 4 of 11
(5,572 Views)
c:\sensor\try.lvm
Windows 7 has more restrictive access for arbitrary locations on the root drive. This is by design.
Message 5 of 11
(5,569 Views)
That is a possibilty, the only problem is that when I deploy the program to another computer does the sam--actually doesn't display an error it just doesn't record... it says <no path>
Message 6 of 11
(5,560 Views)
The Write to Measurement file is simply writing a text file. You can check to see if this is a file system issue by simply trying to use the standard Write to Text File function to write a text file to that same location. If you get the same error, then it's a OS/file system issue, not a LabVIEW issue and you will need to either write to a different location, or configure the permissions as required by the OS.
Message 7 of 11
(5,552 Views)
I had the same problem with my VI, which used "enable" control.
I tested without "enable" control, and it worked fine.
So, I used case structure instead of using "enable" control.
I don't know why it happens, but using "enable" control cause the error with 2009 version.
I tested same thing with 8.6, there was no problem at all with the same VI.
I hope this small tip helps you.
Message 8 of 11
(5,351 Views)
I have also met the same problem on LV2009 Evaluation edition. So, I could not continue running the tutorials on Chapter 3 on the Startup Guide.
I think this is possively a bug on LV2009.
Anyway, I have finally fixed the issue using a Express Relay connector instead of using Enable I/O, it was tough for me since I'm a beginner of LV, though.
Message 9 of 11
(5,282 Views)
You all are correct.  This is incorrect behavior and has been documented by our R&D department as Correct Action Request (CAR) 183624.  Please check the release notes for new versions for if this is fixed.  For any additional information on this issue, please post back to this forum.
Mike S
NI AE
Message 10 of 11
(5,266 Views)
