10-01-2009 09:16 PM
Hi, im using a serial port to continuously read data from an external device with no flow control. Using the advanced serial read/write example, I have managed to keep reading the data (17 bytes at a time, using a while loop) and format it to obtain correct values, so that data is read faster than it is sent to LabView (so no buffer overflow can occur). However, once I start performing analysis on the data within the for loop (such as graphing and formatting the graph), this causes the data to be read slower than it is sent to labView, so that in the end the VI hangs. I was wondering what I could do about this. Maybe I could use multithreading like is described in http://zone.ni.com/devzone/cda/tut/p/id/4575 (Multiple tasks example - simple). I don't mind if I skip some data during analysis and graphing, as long as not too many bytes are skipped. Does anyone have any suggestions on how to fix this?
10-01-2009 09:25 PM
10-01-2009 09:35 PM
Hi Putnam,
Yes, I am doing both acquisition and anlaysis in the same loop (I've only been using labView for a week or so). So what you are saying is to use separate loops for analysis. If I have multiple displays of data, each analysed in a different way (e.g. one is filtered, another is fft'd), would it be a good idea to use a seperate loop for each display? Also, I suspect that the analysis loop would run slower than the data acquisition loop, so if I used a queue to transfer data between the loops (like in the examples you cited), I assume there would be problems? In such a case would it be better to use local variables, or do you have any other suggestions? Thanks for your help.
10-01-2009 09:55 PM
10-01-2009 11:55 PM
Ok, Im having a problem with using multiple while loops. If you look at the attached picture, you can see that i'm just reading data from the serial port once the number of bytes = 17, and then doing some data formatting in the topmost while loop. In the bottom while loop I want to simply add 1000 to a byte read from the serial port. However, the bottom while loop doesnt seem to run, only the top one runs, and channel 4 in the bottom loop never updates its value, while channel 3 in the top loop keeps updating its value. So it seems that the two loops dont run in parallel. Can anyone explain what I'm doing wrong? I want both loops to run in parallel and update their values together if possible.
10-02-2009 12:46 AM
From your block diagram, it is clear that the two while loops will not run parallel.
1. To make it run parallel, create a local variable for the stop control in loop 1 and use it terminate loop 2. Disconnect the wire running between loop 1 and loop2.
2. Also include some time delay in both the loop say for instance 10ms. (No delay in while loop will take 100% CPU usage in causes your VI to hang or even your system to hang).
3. You can also shift all your analysis part to the loop2. acquire in loop 1 and transmit the data via Queue to loop2 and do analysis and display in loop 2.
Hope this solves your issue.
Nanda
10-02-2009 01:00 AM
Hi Nanda,
Thanks for the hints, it appears to work in parallel now. However, with the time delays, the problem I have is that since data is coming in so fast from the device without any flow control, if I have too high a delay, the buffer overflows and the VI hangs, but the second loop has enough time to get alot of data. If I have it too low, then the acquisition loop completely takes all resources and the second loop loses alot of the data, but there is no chance of hanging. I can find a balance between the two, but the problem is then that this particular chosen delay time to get a good balance will only work with this particular macine will it not? If i use the VI on a different machine, then I will run into problems right? Does anyone have any suggestions on how to solve this?
10-02-2009 11:05 AM
10-02-2009 11:16 AM
10-04-2009 04:01 AM
Thanks for your replies guys. The device I am using is basically an EEG/ECG instrument, and when I built it I decided not to connect RTS/CTS for flow control, or put in place any software/firmware flow control. I am currently running it at 57600/115200 baud, and although packets come into the pc at a constant rate, sometimes I lose packets. I will take your advice and implement the acq and analysis as sub-vi's, but I also had another idea. If I read data using the serial port every ms or so (so that data is read fast enough), and place datapoints into a circular buffer, I had the idea then that I could run the display loop every 10ms or so and just take a whole chunk of data that the acq loop has stored in the circular buffer. I was thinking that this approach would allow the acq loop to read data at a faster rate than it is sent to the pc, and also allow the display loop to display all datapoints, but in such a way that the display would update at a slower rate. Then the circular buffer should never overflow as long as I take a large enough chunk of stored data during each display loop. What do you guys think about this approach?
Also, I assume that the main reason to implement the acq and analy/disp loops as sub-vi's is to allow prioritization of each vi? If anyone knows of any similar VI's that continuously read and display data through the serial port, it would be helpful if you could link to them.
