‎12-01-2006 03:33 PM
‎12-01-2006 04:23 PM
Hello Thang,
I am assuming you tried using the Ethernet version of the Master and Slave examples, right? Seems to work fine for me. Just make sure you run the Ethernet Slave example VI first. Wait for a few seconds, and then start the Master VI. The slave VI has to dynamically launch some VIs so you need to give it some time.
-Khalid
‎12-01-2006 04:34 PM
Dear Khalid,
Thank you for your reply. I spent whole day to run this examle, and as your recommendation, but they still do not connet. I understand how they work but just don't understand why they can not connect. I use the IP 127.0.0.1 and port 502. Could you send me your example? I don't sure about mine.
my email is airthang@yahoo.com .
Thank you very much,
Thang Nguyen
‎12-01-2006 04:41 PM
I am using the NI Modbus library as-is -- am not modifying anything. You can find my versions here (scroll down all the way):
http://forums.ni.com/ni/board/message?board.id=170&message.id=86164
-Khalid
‎12-01-2006 05:22 PM
Dear Khalid,
Thank you for your examples. I run these examples on another computer, and they run smoothly
. But they can not run on my computer. I don't know if that is the reason of the version of labview, my computer labview is 8.0, or because I did something stupid on my computer, so it can not run.
Anyway, thank you so much ^__^
Sincerely,
Thang Nguyen
‎12-02-2006 10:30 AM
‎12-03-2006 01:38 AM
‎12-04-2006 04:24 PM
Hello Thang,
You can also refer to this link to get your hands on some quick tutorials on getting started with LabVIEW.
http://www.ni.com/academic/lv_training/how_learn_lv.htm.
Khalid, thanks for helping out Thang with his issue.
Regard,
Chetan K
Application Engineering
‎12-04-2006 07:01 PM
