combine event structures
hello,
I'm having to combine several labview programs together, and some of these programs have event structures with a bunch of cases, is there any programmatic way to combine two event structures?  My finished code will only have one event structure which will be the result of all the other programs event cases combined, I'm trying to avoid having to type all these out
much thanks!
(2,545 Views)
Unfortunately no. You can't combine event structures. The best you can do is take advantage of the opportunity to rework the logic and maybe improve it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,531 Views)
If there is code in the event structures that you need to copy into your new event structure, copy and paste is the fastest way. But as mikeporter said, no easy way to do it.
     Rob
(2,524 Views)
