chebyshev window does not seem to be correct
Hello
Has anybody noticed that in LabVIEW 2009 the Dolph-Chebyshev Window does not produce the proper window for the last element of the signal?
I see it also for other windows, always the last element is missing, or actually all elements are improperly calculated.
cheers
Pawel
Message 1 of 13
(4,355 Views)
Could you please post a simple example that reproduces this behavior? and shows how the value is different from the expected.
Message 2 of 13
(4,332 Views)
Hi
Sure please find it enclosed. AS you can image Matlab has the right answer.
18703i5675D8E8F83FFE35
The code for this is enclosed.
cheers
Pawel
Message 3 of 13
(4,309 Views)
If you implement the formula shown in the help you get something very close to the Matlab result (probably a bug in my code keeping it from being exact).  Looks like they flubbed this one.
Message 4 of 13
(4,284 Views)
What to do about it?
Message 5 of 13
(4,276 Views)
Accepted by topic author pawel
Well, you seem to have Matlab available.  Otherwise you can test out my quick and dirty VI to see if it gives the right result.
It looks like it is time for NI to get a mitt and get in the game.
Message 6 of 13
(4,267 Views)
Thanks a lot for the vi, I will use it for now.
Should I file a request to NI or they will dive in by themselves?
I appreciate your help
thanks
Pawel
Message 7 of 13
(4,264 Views)
thanks
Pawel
Message 8 of 13
(4,263 Views)
It is really hit-or-miss on whether or not they see it here.   I would give it a couple of days and then contact them directly.  They probably would never catch this one on their own...
Message 9 of 13
(4,256 Views)
Will do.
Take care
Pawel
Message 10 of 13
(4,254 Views)
