cannot connect compile server
Hi Rajesh,
I still have the same problem. I already uninstalled all national instruments software and reinstalled the necessary components (LV,RT,FPGA and driver), but this also didn't help.
With regard to compile server: As I said before, there is no process or service looking like compile server. Also there is no tray-icon for the server. That's why I asked where to find the executable. I used Windows search but found only a dll-file.
With regard to compile worker: The worker is running and says disconcertingly everything is okay:
When start compiling LabVIEW I got the following:
The errors in the compile worker log-file are still same, too (see attachment above). But I cleaned up the log-file, so there is only one job and only one attemp. Maybe it's now more manageable.
Michael
Message 11 of 14
(2,470 Views)
Hi Michael,
The compile server and labview interact over the TCP/IP regardless of whether the server and labview are running on the same or different machines. With me, i had a problem in the internet connection due to some malware that was probably affecting all TCP/IP communications and hence compile server was not being connected to. Once i ran my anti-malware and removed it, the problem got solved. So make sure the following:
1. When you see the compile worker window, go to configure ,and make sure the radio button is on use local server
2. try and remove all malware/spyware if any using some anti-malware program.
3. Talk to your internet manager (if you have one) about the network walls/securities, if any, that might cause a problem.
4. Also are you using win 7? if yes, then there are some issues with xilinx not being able to fully support win 7, i dont know about them. That being said, mine is win 7 but it works.
hope you get over it soon. I know how frustrating it is!
Rajesh
Message 12 of 14
(2,461 Views)
Hi Michael..
I am Also Facing Similiar Problems...Have You got Answers for that Problem...
Configs:
LV2014 SP1
Win7(32Bit)
CRIO 9035
Xilinx 14.7
Please Reply Back...
Thanks And Regards
Hameed Ibrahim
Message 13 of 14
(1,781 Views)
Hi Hameedkdni,
Have you tried the troubleshoting steps that rkkallur has recommended?  This issue can come from a lot of different sources.  What have you tried to resolve it, because I would start with rkkallur's steps.
Aaron L.
Message 14 of 14
(1,754 Views)
