1. Do not open more than one forum discussion for the same issue. I have seen you have open 3 for this filter issue.
2. What do you expect to see after filtering the signal? You want the square signal? You should now that a square signal has an infinite frequency response. See this external link:
So if you make that filter you will have a sinewave (delta in frequency).
3. If you want to do it anyway introduce a higher order for the filter. Higher order high accuracy but more calculation time. See example IIR Filter Design (hep -> Find examples) and you can try how it works.
4. Do not introduce a waveform, as you can see the input for this funcion is an array of DBL. For waveforms (in LV 8.0) i recommend you to use the filter function. SIgnal processing -> Wfm Condition -> Filter
5. Visualize the FFT after the filter and not before and you will see how the filter works.
Jaime Cabrera
NI Applications Engineering
Jaime Cabrera
NI Applications Engineering Spain
