array of strings
Which function can I use to see the second element of one array. In my case, I want to use one array of strings, so I want to see the second string of the array.
(1,957 Views)
Accepted by topic author labview99
index array
Tim
GHSP
(1,954 Views)
Thank you so much Tim!!
Best regards
(1,943 Views)
Hi 99,
Simple answer:
  1. set the array index to "0"
  2. resize the array indicator to show 2 elements: now you can see the 1st and 2nd element…
(1,926 Views)
Thank you so much!!
Best regards
(1,904 Views)
