application building error of bdpopup.cpp(5865)
In application buidling, there was an error at bdpopup.cpp line 5865
What's wrong? Please help me.
following is a failure log.
.\diagram\bdpopup.cpp(5865) : DAbort: subvi should not be NULL when trying to relink node
$Id: //labview/branches/Europa/dev/source/diagram/bdpopup.cpp#91 $
0x009A5AC8 - LabVIEW <unknown> + 0
0x00C06C8A - LabVIEW <unknown> + 0
0x0078F5A8 - LabVIEW <unknown> + 0
0x00C06C4F - LabVIEW <unknown> + 0
0x009AC7A2 - LabVIEW <unknown> + 0
0x009A722B - LabVIEW <unknown> + 0
0x009A78DC - LabVIEW <unknown> + 0
(3,230 Views)
I am using LabView 8.2.1.
Any ideas what is causing this?
(3,225 Views)
I found a solution.
If I select "Do not disconnect type definitions" on the Additional Exclusions Page, building process is finished successfully.
(3,218 Views)
I'm glad you were able to fix your problem. Thanks for posting the solution so that other programmers may utilize this information if they run into it as well. Thanks!
Amanda Howard
Americas Services and Support Recruiting Manager
(3,203 Views)
