advance signal processing 2012 64 bit: help missing
I have Labview 2012 64 bit. I have just installed the advance signal processing 2012 64 bit and I discovered that all the wavelet functions have no entry in the labview help. I mean that there is no explanation at all.
Is it normal? Is it due to the fact that I have installed the 64 bit version? Or maybe the installation was not fully successful (I don't know where to check if this is the case)?
Is it possible to correct this issue?
(2,934 Views)
Browse over to <LabVIEW 2012>/readme/readme_ASPT.html
They call it that for a reasonSmiley Wink  Not all Tool Kits have support for 64 bit applications-  The help file will be just fine on LabVIEW 2012 32 bit
You can use the NI License manager to view installed Tool Kits
"Should be" isn't "Is" -Jay
(2,923 Views)
