09-29-2014 08:10 AM - edited 09-29-2014 08:11 AM
Hi all,
i have a code working (supposed) to work on NI 901x and 900x plate-forms. i want to adapt it to work on NI 9068.
i can connect to my CRIO 9068 but the local chassis is stil named (NI 9101), i can change it to CRIO 9068 but the compilation failed when compiling the code (which is a simple use of NI 9870).
what i can do to adapt my code to CRIO 9068?
SASA.
Solved! Go to Solution.
09-29-2014 08:26 AM
09-29-2014 08:47 AM
I would recommend creating the new target in your project and then drag everyingthing from the old cRIO target to the new. Then delete the old target. You may been to recreate your build specs.
09-30-2014 11:17 AM
Hi all,
i think that it is much more complicated, my old code was implemented ino SBRIO !!!
but now i'm able to communicate at least with one instrument, still the other
SASA
