I have three clusters and I would like to save the data of each of them into one text file. One of the clusters is an array. I would like whatever the contol is named followed by whatever the data is. I was thinking of using Write to Text File VI. I was wondering if there was a better way then to manually create the text for each line? Also when I use the ring control it outputs a #, but I would rather it output the string is there a way to do that? The array has 13 elements and I would rather not program each line individually, is their a way to do this prgamically? I am attaching the controls that have the data that I would like to save into one file. What I would like to do is have it look like this when I open the text file:
Patient data
Examinee number:
Ethnicity: ...
Filter paramters
Match mean pixel value:...
Pupil data array
0
Exposure time (ms):...
Camera gain:...
1
Camera gain:...
Until it finishes with all 13 elements in the array. Thanks for any help desinging a output file that can write the name and the corresponding data for each time I change the data.
Kevin Baker
