03-09-2018 09:54 AM
Here is a simplified layout. I changed it up to build the cluster in the frame loop. And I just realized that I didn't convert the coordinates to a string before inserting into the cluster. Unfortunately I don't have time to correct it right now but you should know how to do that from the previous posts.
03-09-2018 10:05 AM - edited 03-09-2018 10:06 AM
Thank you again. I will check with that.
03-12-2018 05:37 AM
I have changed my code by building an Array of Cluster for 'Color thresholds ' for each particles. But, when I run the VI the VI doesn't get executed after 'IMAQ Color Threshold.VI' i.e the frames of AVI doesn't get thresholded. It throws an error at probe 12 as below:
error -1074396120 occurred at IMAQ ColorThreshold
Possible reason(s):
IMAQ Vision: Not an image.
Can you suggest why it is happening that way?
03-12-2018 04:50 PM
Sorry, I am not familiar with IMAQ.
