Where can I find Demo Voltage Read.vi?
I'm a student at Fox Valley Technical College lerning LabVIEW.  I'm using LabVIEW Student Edition 8.5.1.  One of my projects is to use the Digital Thermometer.vi that is included with LabVIEW to generate simulated temperature readings in a VI.  WHen I try to use the Digital Thermometer.vi sub vi in my block diagram, the Digital Thermometer tells me it's looking for Demo Voltage Read.vi which is nowhere to be found in my LabVIEW application or in the learning library I downloaded with my Student Edition workbook.  I've created my own thermometer VI but was wnating to use Digital Thermometer.vi.  I did find a reference to a Demo Voltage Read.vi on the NI.COM site but it was too old for my LabVIEW 8.5.1 to open it.
Is there a newer version available?
Mitch M
(10,860 Views)
Digital Thermometer is not a VI that I can find included with 8.x. It's an older VI that I think was last included with 7.1. In any case, a top-level example in 7.1 that called Demo Voltage Read was called Temperature System Demo. There is an example of the same name in 8.5 that uses a different subVI called Simulated Temperature.
(10,832 Views)
