Weibull fit
Does anyone have a VI that can fit data to a Weibull distribution?
(7,654 Views)
Use "Nonlinear Curve Fit" from the "mathematics..fitting" palette.
Create a model function VI that calculates the distribution for a given set of parameters according to the template. Check the online help for details.
(7,642 Views)
Accepted by topic author brogle
Here's a quick draft (LabVIEW 8.5). Seems to work pretty well given reasonable initial estimates.
Message Edited by altenbach on 12-18-2008 12:06 AM
(7,630 Views)
Yes, that works very well--thanks for the help!
(7,599 Views)
Hello Mr. Brogle,
Hope you are fine.
Please mark altenbach's post as solution to your problem. You can unmark a solution by clicking on the options menu at the top right corner of your post and mark altenbach's post as solution. Hope i understand why i am telling this to you.
Mathan
(7,581 Views)
I have a followup question to this very old topic. In your example the parameters of the weibull distribution are estimated via a Levenberg-Marquardt algorithm which tries to minimize the sum of least squares.
However usually most ststistics programs use the maximum likelihood method to estimate the parameters of the distribution (see e.g. https://en.wikipedia.org/wiki/Maximum_likelihood)
Is there any package available which can estimates the parameters using this method?
(6,224 Views)
Hi there,
There isn't a probability toolkit available for LabVIEW. For that you have to programmatically do it .
regards
(6,199 Views)
