Virtual folder inside shared variable library + multiple variable editor won't work together
Hi All,
LV 8.6 + DSC
In my project I have few thousands shared variables so I need some hierarchy to manage variables. I tested to use virtual folders inside shared variable libraries and that was a good solution. I noticed that when I try setup variables by using "Multiple Variable Editor" I only can modify variables under library root. Is this a bug?
In example pictures this can be easily seen. Columns what I can change, depends variable location inside the library.
BR, Jim
Message 1 of 1
(3,201 Views)
