05-17-2012 10:24 AM
I'm using Lubuntu 12.04 and I need to install VIPM, so I can use the Labview Arduino Toolkit.
I have installed labview 8.6, and I'm using the RTE 2009. I want to Install VIPM 2011, but I get: "couldn't find liblvrt.so.9.0", and I have liblvrt.so.9.0.0.
How can I fix this and successfully install The VIPM 2011, and use it with Labview 8.6?
I'm trying to install VIPM through the command line.
05-25-2012 08:23 AM
Hi Nando:
Could you please specify which command line options did you use to try to install VIPM? It would be really usefull too if you could provide the output of the command line (either a screenshot or the text).
Another question: How did you make sure that you had liblvrt.so.9.0.0 installed? Did you check it in Lubuntu Package manager?
Thank you!
Edgar Cabrera
