Using gcc with Call Library Function
I am setting out for my first time to use C code with LabVIEW.  The "Call DLL" example produced some very helpful C code, which I include at the bottom of this message. Now, I need to know how to build it. I would like to use GCC because it is free, but I have no experience with building DLLs under GCC. Anyone out there have a makefile, a BAT script, or some other helpful example of how to build an appropriate DLL with GCC?
Ken
#include "extcode.h"
/* LabVIEW created typedef */
typedef struct {
    int32 dimSizes[2];
    double elt[1];
    } TD1;
typedef TD1 **TD1Hdl;
_declspec(dllexport) void ARRAY2DHandle(TD1Hdl array);
  int i, j;
  /* dimSizes[0] is the number of rows */
  int numrow = (*array)->dimSizes[0];
  /* dimSizes[1] is the number of columns */
  int numcol = (*array)->dimSizes[1];
  for(i = 0; i < numrow; i++)
    for(j = 0; j < numcol; j++)
      (*array)->elt[(i * numcol) + j] = (*array)->elt[(i * numcol) + j] *
                                         (*array)->elt[(i * numcol) + j];
(3,188 Views)
I have no experience with gcc, but Microsoft makes available Express Editions of their development tools which are also free. So, you can get Visual Studio C++ Express for free.
(3,179 Views)
go to the eclipse homepage, http://www.eclipse.org/, get the IDE (it's free). Get the gcc compiler and register it in Eclipse. After that it's easy to build something, look in the help of Eclipse IDE.
cosmin
(3,163 Views)
Hi Ken,
Take a look at this community post
Joe Daily
may the G be with you ....
(3,141 Views)
