Using a wiimote with LabVIEW
Hi JohannS,
I have a question, i'm trying to make the wiimote work with the dll file, with LabWindows, but i'm not good enough 😞
Can you help me with this ?
Message 11 of 220
(13,936 Views)
Here is an update to the existing Wiimote VIs.
Changes:
*Added support for rumble feature
*Updated VI icons
NOTE: These are the VIs that were used in some of the NIWeek 2007 demos controlled by wiimote's.
Message 12 of 220
(13,882 Views)
Boy I never even thought of interfacing a Wiimote and Labview.  Nice.  I'm going to play with this sometime quick, I've got an extra Wiimote.
___________________________________________________________________
Still confused after 8 years.
Message 13 of 220
(13,866 Views)
There is a known issue when using multiple wiimote controllers and for loops. The Wiimote VI's were originally developed so that each wiimote will have a unique instance of the Wiimote Get <Function> VI. This is demonstrated by the first diagram highlighted in green. Using for loop to get data from multiple wiimotes will result in only the first wiimote being correctly configured to return data. This is demonstrated by the second diagram highlighted in red.
In order to get data from multiple wiimote's, ensure that each wiimote has a seperate instance of the query functions.
Message Edited by JohannS on 08-13-2007 02:23 PM
Message 14 of 220
(13,851 Views)
JohannS,
do you have a copy of the Wiimote VIs that are LV8.0 compatible?  Sounds like some cool stuff!
Jim
Jim
LV 2020
Message 15 of 220
(13,836 Views)
Jim,
Here are the LabVIEW 8.0 version of the Wiimote VI's. Please note that I merely saved the LabVIEW 8.2.1 VIs for a previous version. While the VIs should work just fine, I have not tested the wiimote functionality under LabVIEW 8.0.
Let me know if you have any issues,
JohannS
Message 16 of 220
(13,812 Views)
Thanks Johanns,
I'll give them a try tonight!
Jim
Jim
LV 2020
Message 17 of 220
(13,808 Views)
I don't suppose it would be possible to save the wiimote viis so that they can be opened in version 7.1 of labview?
Cheers,
Bob
Message 18 of 220
(13,754 Views)
I was also wondering if someone could explain how to integrate these files properly with labview. Specifically, how does one use the .dll file with labview (8.2).
I hope to use these vi's as a basis for a school project. Thanks for any help.
Message 19 of 220
(13,604 Views)
I used the "Call Library Function" node to call the wiimote.dll and no errors are caused from that but when the "Wiimote Get Acceleration Calibration" node is activated in the Useage.vi example it spits out an error code. How can i fix this problem? Am I calling the .dll incorrectly? The wiimote is definately communicating with my computer via bluetooth so I'm not sure whats wrong. Thanks for any help.
Message 20 of 220
(13,496 Views)
