Use Wii Balance Board in LabVIEW
The function only adjusts the offset (zero calibration) and return the value of the sensors. To find weight you need add all the sensor values and adjust the ratio of the weight. The relationship tested in some boards was 102 units per kg. approximately, then to get the weight you need divide the sum of the sensors between 102 and get the weight in kg.
Ex. If the sum of the four sensors is 7742 then 7742/102 = 75.9 kg.
Message 11 of 77
(4,373 Views)
Ross I've just gotten hold of the published research and congratulations are due to you and your team.  I bet gait scan and Kistler are quaking in their boots and a round of discrediting will ensue... but much appreciation from one of the little guys..  please please share the code it will revolutionise rehabilitation, patient education and research opportunities..
Kudos to you all
Gnarly-Dude Smiley Very Happy
Message 12 of 77
(4,266 Views)
Congratulations too to Ross and his team for the article in Gait & Posture
Message 13 of 77
(4,230 Views)
Below is the link for any who are interested in reading this research.... apologies I meant to put this in my last post....
http://www.sciencedirect.com/science/article/B6T6Y-4XX26BC-2/2/65da29bedf4047227c7a3948819c8e16
Gnarly-Dude
Message 14 of 77
(4,208 Views)
hi, i have unzip the balance board file, but can you tell me how to run this file? do i have a project file to run this? thanks very much!
Message 15 of 77
(3,673 Views)
hi, can you tell me what else do i need in order to run this wii balance board file? i tried to run this file but the computer displayed some report error, like Wiimote Set Output Report.vi:13 and Wiimote Get Input Report.vi:1.
what dose that mean? and what should i do to fix this?
Thanks very much!
Message 16 of 77
(3,667 Views)
hi Ross, just wonder how you implement your program using the wii balance board file. is it possible that you can upload your program? thanks very much!
Message 17 of 77
(3,665 Views)
Message 18 of 77
(3,654 Views)
Thanks. i have downloaded both files. so what should i do next? should i run the VI file Usage_WiiBalanceBoard.vi directly or should i run other files in order to interface with the balance board? Thanks very much!
Message 19 of 77
(3,647 Views)
Run  Usage_WiiBalanceBoard.vi directly. The only file that is not included in the Wii Balance Board zip file is wiimote.dll, that is included in wiimote.zip.
Be careful with the index that normally is 0.
Message 20 of 77
(3,630 Views)
