Use Read from Measurement File to Create Array
Good morning!
I have some data logged in .lvm file format.  I would now like to arrange this data in a sequential array so I can apply a median filter to it.
When I run the VI I notice that the first element of the indicator seems to be getting overwritten on each loop (rather than going to the next element), I think the array should be built outside the loop but I am unsure how to code this.
Please find my current VI attached.
Peter
Peter D
(4,422 Views)
Accepted by topic author Pete.Dunc
use shift register... See the attached snippet
Regards
Guru (CLA)
(4,410 Views)
Thank you!  It has been a while since I used shift registers (or LabVIEW for that matter!).
Peter
Peter D
(4,399 Views)
