Upconvert VI Requests
Can someone upconvert the last sent 5.1 vi to 8.5. Because when I downconvert from the 11.1 some vis are not well converted. Thanks a lot in advance.
Message 1211 of 1,261
(1,431 Views)
Which last VI? Your last upconvert request was a library, not a VI. And before that you re-posted the libraries which had already been done.
Message 1212 of 1,261
(1,416 Views)
Can someone help me upconvert the file of  Labview 5.0 to labview 8.5 please?
source LabVIEW version: 5.0
target LabVIEW version: 2009
Thank you very much. Happy Holidays
Message 1213 of 1,261
(1,399 Views)
I got an Oscilloscope driver converted from version 5.1 to Version 8.2 from this thread, sometime back.
It works fine on one of my PC and doesn't gives an error in my other machine with the exact same specs. Previously I thought it might be because of IVI
compliance package, but after installing that also. I am getting the same error.
The error is in the "lcwpxxx IVI Error Converter.vi" and the error is "Call Library Function Node 'error message' : Library not found or failed to load".
Can someone please guide me what might be the cause of this error.
The convereted zip file of the driver is also attached.
thanks
Message 1214 of 1,261
(1,389 Views)
You need the lcwpxxx_32 DLL. The drivers are wrappers around that DLL. If the DLL is not on IDNET then you need to get it from LeCroy or simply copy it from the other machine.
Message 1215 of 1,261
(1,380 Views)
Not clear whether you want it for 8.5 or 2009, since you've indicate two different targets. So, you're getting it in 8.2.
Message 1216 of 1,261
(1,381 Views)
Sorry about that.
Since my computer is 8.5 and my lab computer use 2009. I think if you convert to 8.2 and 2009 and 8.5 could accept it or
not ?  If 2009 can't read what you convert, could your help me convert it for 2009. Thank you very much.
Message 1217 of 1,261
(1,378 Views)
Why don't you simply try to open the 8.2 VI?
Message 1218 of 1,261
(1,374 Views)
@Kedoby wrote:
Sorry about that.
8.2 VIs can be opened by either 8.5 or 2009. That's why I provided it in that version. Smiley Wink
Message 1219 of 1,261
(1,368 Views)
I wonder if you can upconvert these LLB:s from v5.1 to v8.5.
Best regards / Anders
Message 1220 of 1,261
(1,359 Views)
