06-25-2015 06:44 PM
I am using Matlab script in Labview to find the zer of a function using Brent method.. I got this error massage when I run the code"Undefined function 'function namet' for input arguments of type 'double'... The same function runs fine when I use it Matlab code. I attached the LV code but could not attach the matlab function due forum policy
06-25-2015 07:35 PM
Is that function supported by the mathscript node? Did you go through that readme?
06-25-2015 09:58 PM
It is custom build functionto with .m extension. It was written by a collabrator of mine using matlab. I would like to using the same function instead of writting it again. If you mean NI mathscript, I do not have a license to try it.
