Unable to drive the correct width of VISA Resource Name control
Impossible to obtain the correct look of a VISA Resource Name control when the width is changed programmaticaly (using the property node Width) .
(and more, when the appearance is changed, the manual resizing is difficult because limits of the object are not celar any more...)
Tested with LV8.5.1 and LV2009
Any idea?
23116iECFE64CB38044321
(3,288 Views)
I was able to confirm this asthetic anamoly in labview 2010. This issue is currently listed under 2 CARs (Corrective Action Request) to R&D. These numbers are CAR-197025 and CAR-60751. Thanks for your diligence in finding and posting on this issue on your own.
(3,275 Views)
Thank you Joel.
I will see later if I try to find an other way for my problem.
(3,263 Views)
