10-12-2021 02:57 PM
Has anyone found a USB relay board that works with LabView, preferable with drivers?
10-12-2021 03:22 PM
I never used it but a quick Amazon search turned up this:
https://www.amazon.com/Channel-Relay-Module-Board-Automation/dp/B06X99QX61
It says it has LabVIEW examples.
10-12-2021 03:24 PM
If you're looking for a low-cost option, you can try
https://numato.com/product/16-channel-usb-relay-module/
https://numato.com/kb/understanding-readallwriteall-commands-for-relay-modules/
I believe it supports automation through commands over serial - you can use VISA APIs to control Serial port.
