Hi there,
On several occassion when I USB-8451 to change my EEPROM IC data, the software prompt me "I2C master lost arbitration and failed the seize the bus during tranmission of a data byte" or "I2C master lost arbitration and failed the seize the bus during tranmission of an address+direction byte" or "The connection for the given device handle has been lost".
For every 10 tries, at least 50% will prompt me error messages. When there is no error, the data is changed successfully.
I have attached the vi, EEPROM IC spec file and error message print screen.
If possible, pls kindly let me know what is the possible cause.
Software: LabVIEW 7.1
Thanks & Regards,
Norman
