04-11-2007 04:44 PM
04-11-2007 04:55 PM - edited 04-11-2007 04:55 PM
you can use the queue in two parallel loops in the same vi as shown above or use them in separate vi's.
To use them in separate VIs you still need to obtain the queue but as long as you give the queue a name that you created previously you can access the data.
One more tip is to make sure you make the "create if not found" input false on the queue's that you are proessing the data so you know when there is not a source queue and you can exit gracefully.
Message Edited by James R on 04-11-2007 05:07 PM
04-11-2007 04:56 PM
04-11-2007 05:05 PM
04-11-2007 09:15 PM
The UDP read loop had an UDP read with infinite timeout, writing the data to the AE above. Nothing else really. The analysis part read the currently accumulated buffer data, analyzed it, retained the packets matching a desired pattern, and appended them to disk.
04-17-2007 04:19 AM
04-17-2007 07:49 AM
09-23-2014 12:13 PM
Hello, would it be possible for you to post your solution?
joe
09-23-2014 12:28 PM
Rohrdt hasn't been in the forums for nearly 4 years. So I doubt he'll respond. You also responded into another even older thread.
I recommend you start a new thread with your question. First look in the example finder for UDP. Then browse the forums searching on UDP and read the responses without replying into all the very old ones.
If you still have questions, then start a new thread with your question. Be descriptive on what you are trying to do, what you have done so far, and where you are stuck.
