Turn off icon numbers in new sub-VIs
New in 2009 per the help file
"Should be" isn't "Is" -Jay
Message 11 of 13
(1,481 Views)
Hi!
After installing last version (LV 2012, SP1) I've got the same problem.
I've found this post, changed the option "Use numbers in icons of new VIs (1 through 9)", exit and re-run LabView. But numbers in new VIs are still there when I'm overriding a method in the ancestor class!
Help if possible, please.
Ljubo.
Message 12 of 13
(1,440 Views)
 I'm in 2013 and adding the "UseNumbersForNewVIIcons=FALSE" to my LV .ini file just now worked for me. Have you given that a try, Ljubo?
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 13 of 13
(1,366 Views)
