Tree Control Bug
This is a cross post from LAVA (Tree Control Bug)
Version Affected:
This bug affect (at least) LabVIEW 2010 and LabVIEW 2009 (I did not test it on any more version)'
Platform:
Windows (XP and 2007)
Description:
If you have a tree control with filter event case for "Edit Cell?", "Item Open? and "Item Close?" then clicking the node expand/collapse glyph (the"+" or "-") while editing another column will result with the text entered be applied to the node column (the first column) instead of the column that was being edited.
More info:
See attached video and attached example VI.
vipm.io | jki.net
(3,355 Views)
Could you post a link to the video so I can attach it to the CAR for this?
Joe Daily
may the G be with you ....
(3,304 Views)
Certainly.
Here you go: http://screencast.com/t/NDEyYTJk
PJM
vipm.io | jki.net
(3,284 Views)
I filed CAR# 243655 on this issue
Joe Daily
(3,251 Views)
