04-17-2009 04:13 PM
Hi everybody,
I am new to labview and have run into some difficulties with the DAQ assistant. I am running labview v8.0, NI-DAQmx v8.7.1 and have a PCI-6224 DAQ installed. It seems that when ever I drop the DAQ assistant (the instrument assistant, and the simulated DAQ has the same issue) onto the block diagram, and configure it, there are no inputs or output which I can wire a control or indiactor to. Is there a step that I am missing somewhere?
Thanks in advance!
04-17-2009 04:19 PM
04-17-2009 04:26 PM
04-17-2009 06:01 PM
I feel dirty, I used an assitant for the first time. 🙂 I double clicked on it in your vi, some config panels/tabs came up, clicked on OK and then it built some LabVIEW code around it. The assistant then had inputs and outputs to wire to.
Sounds like it did not build the code in your case, not sure as to why yet. This is new to me.
-AK2DM
04-17-2009 06:04 PM
Sorry, forgot to attach the end result. Note I did have errors come up, they may have been due to no DAQ cards in my PC.
-AK2DM
04-20-2009 09:07 AM
04-20-2009 09:19 AM
04-20-2009 11:07 AM
04-21-2009 09:38 AM
Try to repair the DAQmx Driver through the control panels and see if that solves the problem.
How Do I Uninstall or Repair NI Software?
http://digital.ni.com/public.nsf/allkb/AC6ED75D3D93375686256E8E00245F0D
04-21-2009 10:18 AM
