TDMS File Creates Multiple Tabs of Data. Want to create only one.
Hello NI Community,
I am currently using the DAQ Assistant with my string pots to record displacement over a long interval of time (see attached VI). I am then using the "Write To Measurement File" vi to save the data into a TDMS file (see the "Write to File Settings" picture attached for all settings chosen for file write). The file is being written, however when I open the TDMS file, the document creates a tab in Excel for every second of data recorded (please see the attached "). It looks like the TDMS file is grouping all the data from each second together and then creating a new group of data.
How do I get the file to write all the data onto a single tab instead of creating multiple? I do not want to have to concatenate hundreds of tabs into a single excel sheet.
Chris
(3,155 Views)
Accepted by topic author cjwarren
You should not be using the comment.  I just removed that and it all worked for me.
GCentral
(3,141 Views)
You are an NI hero.
(3,130 Views)
Double-click on the express VI and set Segment header to "One header only".
(1,378 Views)
