01-13-2016 07:55 AM
I added a TC-01 read in one program that causes another program to lose communication with a serial device (Keithley 6487 Picoammeter). Both programs are written in LabVIEW. The TC-01 is a USB device and the serial device is connected using a USB-serial converter. Can you suggest something fundamental that I've missed that could cause this phenomenon?
Thank you.
01-13-2016 08:01 AM - edited 01-13-2016 08:04 AM
USB Arbitration / USB Host issues? How many USB ports do you have / are you using any hubs? What is the chipset of the USB-serial converter - some of them are notoriously unreliable (e.g. I've had one cause bluescreens...it's not unreasonable that it might cause problems with other devices).
You could try connecting one to a different USB port as it might be on a different controller (e.g. some motherboards have the USB controller on the southbridge and then there is an additional 3rd party controller for additional ports).
It could also be a power issue - perhaps you could try a powered hub (although hubs usually make things worse, not better).
01-13-2016 08:11 AM
What is a "TC-01 read"? Are you talking about the NI USB-TC01 Thermocouple Measurement Device? Does it appear (in MAX) as a VISA device? I assume your other serial device (which, I gather, is also plugged into a USB port via the USB/Serial converter) also appears as a VISA device. Is there some code you could show us? [I'll spare you my "rant" about attaching code, not pictures ...].
I'm also confused by how adding a read "in one program" causes "another program to lose communication with a serial device". Now that I re-read your Post, it sounds more like plugging in the TC-01 clobbers the earlier program, is that right? Or does running the TC-01 program render the second program non-operational? What is the sequence that causes the problem? What can you do to clear it? [Does a log off help? A reboot?]
Are you plugging these two USB devices into the same USB controller? Using a Hub? Does either (or both) get power from the USB line, and could that cause a problem? Might this be a "hardware issue"? [We Software Guys almost always blame the Hardware ...].
01-13-2016 12:27 PM
Yeah my only suggestion would be as others have said, port selection. If they are both plugged in directly to the motherboard then that probably isn't it, but I'd try a few port combinations maybe with a hub. If you are on a shared hub can you slow down the DAQ rate of the TC01? Temperature is probably slow anyway and a single point once a second is probably sufficient.
Oh and also not all USB-232 adapters are the same. I've had some inconsistency issues with some that are plugged into hubs when using some of the cheaper ones.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
