10-21-2011 07:42 AM
To replicate a NI-9074 I use the executable from the RT System Deployment Utility (rtcp.exe, ftp://ftp.ni.com/support/labview/labview_rt/SystemReplication/RTSystemReplication8x.zip)
The problem is that I get attached error message when I try to access the NI Web configuration pages when I deploy a full backup.
Taking a "Installed Software" backup, I get access to the NI Web configuration pages. But I must get the same error, but a refresh fixes this problem.
To be able to create a backup that supports both my project spesific files and the NI Web configuration pages, I have to manualli merge the two backups.
Anyone else having this issue or know why I have it?
Solved! Go to Solution.
10-21-2011 08:57 AM
Looks like I reproduced the problem with deleting the tmp folder on the cRIO.
Does the "NI Web configuration pages" need files in tmp folder to work?
10-27-2011 06:43 AM
