11-22-2012 02:34 AM
Maybe someone can give some advice. I am reading temperature data from a Fluke 2620a Hydra. I got that part to work, a temperature reading every few seconds is fast enough. The Fluke outputs a string containing a number of temperatures for each scan. Each scan outputs a string, something like +0023.7E+0, +0025.6E+0, +0023.8E+0,......
9 probes are measured. For each string I can scan the string for a number string, convert it to a number and add this number to an array.
Say the temperatures are 1,2,3,4,5. I end up with a 1D array, 1 2 3 4 5 1 2 3 4 5 12 3 4 5 1 2 3 4 5...........Writing this to a LVM file results in 1 column with all these numbers.
What I need is a row of numbers for each scan, like so (an additional column would be time)
1 2 3 4 5
1 2 3 4 5
1 2 3 4 5
I am having a brain freeze and I just can't figure out how to do that.
Also, I need to display these temperatures in a graph. If I have the temperatures in an array I can manipulate them and do the required calculations.
If some has a suggestions that would be great. I am using Labview 2012.
Attached is the part that needs to do this. The 1,2,3,4,5 string would be the output of the Fluke and would be read until stopped.
Thanks in advance
Arne
Solved! Go to Solution.
11-22-2012 02:37 AM
could you quickly post it in Lv2010? I will have a look at it
11-22-2012 03:05 AM - edited 11-22-2012 03:06 AM
Double-click on the "Convert to Dynamic Data" VI and change the type to "1D array of scalars - multiple channels". That will give you:
1 2 3 4 5
1 2 3 4 5
Problems with the VI as supplied.
11-22-2012 04:31 AM
Set the file write to "append to file"
Initiaize the shift register with an empty array. Just use Spreadsheet string to array with comma as delimiter.
Convert to dynamic data as "1D array of scalars multiple channels"
Try the attached.
11-22-2012 04:35 AM
11-22-2012 03:58 PM
Thanks for all the replies so quickly. I will try to attach the vi for version 10 for the person that asked. I will try the solutions suggested and report back.
11-22-2012 05:38 PM
This seems to work with an artificially constructed string. I think it will work with the Hydra, i wont be able to test this until Monday.
One last question. What is the easiest way to add a timestamp column to the data written to the measurement file?
Going through the Core1 labview course right now. I have a lot to learn obviously!
11-22-2012 10:38 PM
From your VI, the simplest way would be to use the Format Date/Time string VI and leave the time stamp input disconnected (this defaults to current date and time). Run the string output into the "Comment" input of the "Write to Measurement File" VI.
11-27-2012 01:32 AM
Thanks everyone. I have things working correctly now.
