Stopping parallel while loops in case
Hi all,
I have parallel while loops running (DAQmx continuous read) in a case (in a case structure). The cases are selected by messages in a message queue. What is the elagant and professional way to stop the loops and be able to switch to another case? As I understand, the case selector won't read the value while the inner loops are running, right? I would like to avoid involving a new queue to send the stop message to the wile loops.
Thanks for the advices in advance.
(824 Views)
Hi farkas,
Why are there several loops inside several cases of a case structure?
Which kind of program architecture did you choose?
You're right, you need to "OBEY DATAFLOW!"
The elegant way is not to bury several loops inside several cases of a case structure, but to employ some good architecture…
So then start again with a better architecture!
Btw. yor forgot to attach your VI(s)…
(811 Views)
You answered your own question.  To stop a Case that contains two While Loops operating in parallel, you only need to stop the two While Loops.  Surely you have Stop conditions for them, right?  Too bad we can't give you more advice about the architecture of your code-that-we-cannot-see ...
(806 Views)
That was a very constructive reply. Thank you.
(746 Views)
Which one?
What are you gonna do now?
Greets, Dave
(725 Views)
