10-31-2017 11:58 AM
Hi
check this one
10-31-2017 12:02 PM
png file..
11-01-2017 12:13 PM
I'm going to go back and give your For-loop a try again. Was working on another issue, and I think I figured-out the issue with that (missing "Auto-Index" tunnel).
My "solution" version is still delaying.....just takes longer to notice it. I'm doing a test run this afternoon, and it's already 3 minutes behind after 30 minutes.....
11-03-2017 10:08 PM
attached vi please
11-06-2017 08:52 AM
Were you able to resolve this or are you still running into issues? If you're still seeing the delay problem, I would also encourage you to post you VI here so others in the thread can take a look.
11-06-2017 09:01 AM
Yes, I'm still running into issues.
The VI is already attached.....? Last post on page #1 "Chart_formatting_fixed.vi"
What's causing most of my issues are delays in other parts of the VI. The timeframe isn't always consistent, has the hardware doesn't gather data on a Periodic basis....except when idling. Everything else is event-driven....which messes-up the chart timing.
