It is possible to influence the input terminal used when an object is inserted into a wire. For example, LabVIEW help says under the heading "inserting, objects on block diagram" the following: "Right-click the pixel of white space directly above the wire or right-click the wire itself to connect the wires to the most appropriate terminals at the bottom of the object. Right-click the pixel of white space directly below the wire to connect the wires to the most appropriate terminals at the top of the object."
I would like to know if there is some analogous way to influence terminal selection when existing wired objects are replaced on the block diagram?
For example, if a N
EGATE node is replaced with a MULTIPLY node, is there a way to force the selection of which of the two input terminals on the MULTIPLY node are chosen to be connected to the existing incoming wire?
