Shared Variables RT Target Deployment Issues
I am using a cRIO-9074 and labview 2012. Ive run into a issue that I haven't seen before where recently added shared variables, don't appear to work while the cRIO is running from start up. I have added some shared variables; two array of doubles and a integer, to my project which are being sent through a data stream to a HMI, When I deploy the VI to the cRIO from the project the variables in question work perfectly. I am able to see the data on the HMI. However, when I build and deploy my RT executable, the recently added shared variables do not work yet other shared variables work fine.
I'm at a loss as to how to tackle this problem.
(2,359 Views)
Where is your SVE running (RT or Windows PC)?
Beside your RTexe there is a *.aliases file that points to the SVE. Check that against what you expect.
Hope it helps
Christian
(2,305 Views)
Another thing I would check is if all the shared variable lvlibs are listed as "always included" in the "Source files" tab of the RTEXE's definition.
Hope this helps
Epictetus
Antoine Chalons
(2,300 Views)
Hey T._P_Tithering…,
Hope you're doing well, please take a look at this article which hopefuly could be helpful to you:
"How Do I Deploy Network Shared Variables from a Compiled Executable?"
http://digital.ni.com/public.nsf/allkb/04D9A85B6967EE87862571140065EEC6?OpenDocument
Daniel C.
(2,262 Views)
