Scope for Real-Time audio DSP Project
I have a DSK6416 board and it is supported in my LabVIEW DSP Module on my LabVIEW 8.6 Professional. I am running a real-time audio project on it, using Code Composer Studio. I just want to measure the input and output audio signal with LabVIEW. I want to use two scopes, one for the input audio signal and one for the output audio signal of my board. Which one should I use? NI-SCOPE or Two Channel Oscilloscope? Does NI-SCOPE support any dsk? Does two Channel Oscilloscope work with my real-time project?
(2,739 Views)
NI-SCOPE only supports our high-speed digitizers, not anything 3rd-party.  By "two channel oscilloscope," are you referring to this [broken link removed; example no longer available] example?  I did a quick search for some examples for the DSK6416 and I came across this post.  Let me know if this is usful to you at all.
(2,709 Views)
