Restarting a while loop
while my program is running, I need to restart a while loop from a boolean control, or some other control. But once I stop the loop I cannot restart it. Can anyone help?
Message 1 of 10
(21,312 Views)
Try putting the loop you need to restart inside a case structure, and put that inside another while loop. When the inner loop stops, keep the outer loop running with your boolean control on the case structure preventing the inner loop from running.
When you want to restart the inner loop, toggle the boolean to switch to the case with the inner loop and it will start running again until you stop it and control will return to the outer loop again.
Use a shift register on the outer loop to pass the boolean value for the case structure.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 2 of 10
(21,312 Views)
Thanks Ed Dickens, It also helped me.
Message 3 of 10
(18,443 Views)
Instead of having loops inside loops, you can do everything with a single loop and a proper state machine architecture. Instead of stopping the loop, you simply go to the idle state while staying inside the loop.
Don't overcomplicate things.
Message 4 of 10
(17,504 Views)
Hi Folks,
does it make sense to make a while in case in while structure if the inner loop is a timed loop?
aiming to free up some ressource?
best regards
Sergio
Message 5 of 10
(16,939 Views)
Why would that "free up resources"?
Message 6 of 10
(16,896 Views)
Because a Timed Loop is (normally & in my case) way faster than a simple while. So LabView would have more time to do some other things than running a time critical loop with idle state, or am i wrong?
Message 7 of 10
(16,857 Views)
A time loop is more precise, but that has nothing to do with efficiency. Typically the loop timing is determined by a wait statement or by the timed loop configuration. Only if the loop contains more code than an be executed in the allocated time, the loop timing will depend on the exection time of the code inside the loop. Since this is highly dependent on the computer hardware, it should typically be avoided.
What you are describing makes absolutely no sense.
Can you attach an example of the two types of loops, what they are doing in your code, and how you are measuring the "speed" (whatever that means).
Message 8 of 10
(16,849 Views)
I am using a while loop to gather data from a spectrum analyzer and I would like for it to go quiet after getting the last sample. However simply stopping the loop leaves me with a dead loop that I can't restart. Using your state machine example sounds good but as I have only recently started using Lab View I am a little flummoxed on how to proceed. Would I place a SM inside the main while loop and then route signals through it? Can you point me to some suggested study material that may help?
AF6ND On the Air
Message 9 of 10
(12,010 Views)
Look at the design templates that ship with LabVIEW. There are also example programs.
Message 10 of 10
(12,009 Views)
