Real time graph
I got confused with someone's question while discussing.
Need to clarify some basics:
What is a Real Time graph with continous acquisition?
1. Chart, waveform, XY graph, all can show real time data.
2. Do we need to set the X-axis with date/time icon or some time stamp? I need every second value.
3. If I am using DAQ VIs and I use DAQ read and directly connect the waveform with the incoming data from the channels? Is it not real time data?
Please clarify!
(2,532 Views)
Could you clarify a couple of things about your application? Specifically:
1. How are you defining "Real Time" in this context?
2. Could you give a little more info about your system and how you're acquiring data? That will help to answer your third question.
(2,491 Views)
Hi frnds we need to implement a real time in a normal graph (labview).... Pls help me to do that....
(2,437 Views)
What do you mean by "real-time" and why can't you spell out "friends"  and "please"? This is not a text messaging site.
(2,435 Views)
Adding to that you have to start a new thread to ask your queries
(2,428 Views)
Sorry friends.....
Real time is Current time,,, i just want to plot it across x-axis????
(2,421 Views)
If using DAQ, then you can select to acquire a waveform or waveforms. Waveform data includes time information (start time and delta t) which is shown automatically on the Waveform graph on the X-axis. If you want a "scrolling graph" then use a Waveform Chart.
(2,418 Views)
