09-13-2013 02:27 PM
Hello again all you helpful forum-goers!
I feel silly posting about such a trivial issue, but I don't know what else to do at this point. I have a real-time target PXI chassis that has two LEDs labelled "User", and I am trying to use the "RT LEDs" VI to light one of them up. However, I get an error with code -1 and source "Invalid LED number or state" when I do so. I have tried various combinations of 0, 1, and 2 for both inputs, to no avail. Any ideas what might be going on?
Thanks for your help as always,
-Joe
09-13-2013 02:49 PM
Don't have the answer for you, but I would take a look at the manual for the chassis. Maybe it contains the magic numbers?
09-13-2013 02:55 PM
Hi Joe,
What model PXI controller is this? As ToeCutter said, the information you're looking for is likely in the manual (whether or not the LEDs are two-color, for example, will affect how you can use the function.)
Also refer to
LabVIEW Help: RT LEDs VI
http://zone.ni.com/reference/en-XX/help/370622J-01/lvrtvihelp/rt_board_leds/
and you may want to post on the RT or PXI forums rather than the general LabVIEW forum.
09-13-2013 03:10 PM
Hi Tom and ToeCutter,
This is a NI PXI 8119 chassis (sorry I didn't have the number in front of me for my first post). The page on it is here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210546
Reading the manual, on page 3-15 it says USER1 LED and USER2 LED are both bi-color green/yellow. No other mention of number associated with it; reading that I would assume the numbers are 1 and 2. No other mention of those LEDs are in the manual.
I looked at this page from NI:
http://digital.ni.com/public.nsf/allkb/6E8694E997B5FCB3862572CE00463067
Which made me think the numbers just start at 0 and go up, but then I noticed it was for cFP and cRIO devices, so that may not apply.
You are probably right about this not being the ideal forum; I tend to post here by default. 😉 Thanks for the suggestions.
-Joe
09-14-2013 11:47 AM - edited 09-14-2013 11:47 AM
It should wook as long as you're calling the function like this:
Typically the top left terminal named LED Num is incrementally assigned to the USER leds (usually, 0 is USER1, 1 is USER2), and the lower terminal named State corresponds to 0=off, 1=on with some color, 2=on with some other color.
What version of LabVIEW are you using? What BIOS version does the 8119 have?
09-15-2013 10:27 AM
Hi Craig,
That is exactly how I am calling the VI. I am using LabVIEW 2012 SP1. Can you remind me how to check what version of the BIOS is in use? If so I'll get that to you as well.
Thanks!
-Joe
09-15-2013 12:15 PM - edited 09-15-2013 12:16 PM
Hey Joe,
If you hold DEL while the system is booting it should go into the BIOS settings. From there the BIOS version is typically on the main information page.
You can find more information on this in the manual on page 2-4: http://www.ni.com/pdf/manuals/373721a.pdf
09-16-2013 09:20 AM
Good morning Craig,
Thanks for the info. The BIOS version turned out to be 1.0.0f0. I hope that that means something to you with regards to the problem I'm having. 😉
-Joe
09-17-2013 01:25 PM
Hi Joe,
Please try and see if the example code in this link works for you. This example is for a cRIO but should also work on the PXI.
Regards
09-17-2013 01:38 PM
Arham,
It looks functionally identical to what I am doing, but I'm happy to give it a shot in case my code somehow got corrupted or something. However, I cannot download zip files at my work. Can you post it here as a VI, or renamed as a .zit file?
Thanks for your help!
-Joe
