RMC not supported in NI 9684 Inverter controller when updating from LabVIEW 2017 to 2020
Dear all,
We are working in a project in which we want to control a Semikron Power Inverter. For that purpose we are using a sbRIO-9607 with NI 9684 and 9687 Inverter controller boards.The first version of the project was developed using LabVIEW 2017, and the RMC was identified correctly (see image below).
The problem comes when we want to update the software version of the sbRIO-9607 (we do it with NI MAX), from 2017 to 2020 version.
As you can see, the 2020 version does not support the RMC 9684 when we open the project. Similarly, we try to create a new FPGA project including the sbRIO hardware, and the problem persists. Our conclusion is that the 2020 version of the C Series Module Support does not support our board.
Has any of you got somethin? How did you fix it?
Thank you in advance
Message 1 of 1
(167 Views)
