NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
jonrie1
Accepted Solution
Producing data to a loop with an event structure
I'm relatively new to Labview programming (as will be seen in my program below). I found a vi online that collects data from a 9237 bridge analog USB card. That is the top portion of the vi is what collects the data. The original place the output in a graph, but I have changed it to a numeric indicator.
The lower portion I'm trying to have the operator use the start, stop, reset buttons to interact with the system. I used an event structure to do this. Every this works well, except for the event that the value of the load cell data (from above loop). I want it to act on the new value continuously, but it only acts one time. All other features work fine. Can someone explain how I would best accomplish this?
Any help would be apprciated.
Knight of NI
RavensFan
Re: Producing data to a loop with an event structure
Why are you using a queue to pass the data from one loop to the other?  The reason it only works one time is that the lower loop will wait until an event has occurred.
I would eliminate the queue.  Wire the Total into a property node for Total Value (signalling).  That will trigger the event case for the Total: Value Change event to fire.
Don't read from property nodes in the upper loop when you have the indicators and wires right there to read from.
Trusted Enthusiast
Norbert_B
Additionally, this below is a no-go:
Norbert
Member
jonrie1
Actually the producer/consumer with the queue was a recommendation by one of the ni techs when I called for tech support. I originally had a property node but I was using Value, not Value (signaling). You suggestion did the trick.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
