01-15-2015 12:42 PM - edited 01-15-2015 12:43 PM
Hi guys, I am brining in a signal using the Daq Assistant, and am trying to use a smoothing filter to reduce random noise. However, it appears that the filter is demolishing the signal (all of my values are staying within 1/100th or so of my load cell calibration constant. My guess is that this problem has to do with the wire type (it is currently dynamic), but I am not certain.
If it is the wire type, how can I go about creating a functioning signal that isn't the obnoxious dynamic type?
Attached is a copy of the VI.
Thanks in advance!
01-15-2015 01:19 PM
Can you show us some sample data? (Just put an indicator on the DAQ Assistant output, run the vi and change the indicator to a constant)
