Pass data to SubVI state machine
Greetings,
I'm having trouble passing data to a State Machine that I've made into a SubVI.
I know there's something very important I'm missing here.  But I don't know what it is.
I need to be able to pass Start and Stop booleans to this SubVI.  But once the SubVI starts, I am unable to pass any data at all to it.
I've tried making the VI reentrant.  But that didn't help.
I know there's a way to do this.....I'm just having a hard time finding it.
Can anyone point me in the right direction?
Patrick Allen: FunctionalityUnlimited.ca
(3,616 Views)
Queues are the usual way of passing data between independent loops.
Lynn
(3,617 Views)
The only "data" I'm actually passing are boolean values.
Is a Queue still the way to go?
(3,605 Views)
...and if you're looking for the easiest way, you could just use a Global Variable to pass the loop stop condition between the VIs.
-D
(3,604 Views)
Are your problem solved?
(3,412 Views)
Have you considered calling the SubVI by reference and setting the Wait Until Done property to false?
(3,392 Views)
